Model 16, Code 125
With it misbehaving touch the grid cap of the 78 rf amp and then the 77 mixer tube. Does that stop the noise?
I tried as suggested. It didn’t seem to make a difference, other than completely killing the entire signal when I touched one of the tubes.
So, I plugged in and ran 3 different radios, including a more modern (1970s-80s) unit. Apparently the signal I’m getting is something new to either the house or area. Icon_evil I wasn’t getting it earlier (a few weeks ago), so I thought it was specific to this recent restore. It’s not specific. It is affecting my other radios in the same frequency spread. So that resolves this problem. Icon_crazy
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
The final test will be when I get the 16 home and try it. My guess, there is a transformer or some such device near Jeff that it splattering out a spurious signal. I've seen that same sort of thing happen on the ham band. We'll see! Thanks for your hard work, Jeff!!
There are currently 4401 online users. [Complete List]
» 1 Member(s) | 4400 Guest(s)
