Photo Finish or Real Veneer?
Hi,
I was "required" to buy this 40-140 for $14.40. I know, odd price ($18 - 20%). Actually my wife did suggest i get it!
Is the band of "veneer" below the dial actual veneer or some sort of "photo finish"? I'm not sure how to easily and non destructively test it.
It needs a new dial cover and a couple of knobs, but is otherwise pretty good. The back cover is in just about perfect shape.
Greg
Greg O.
Whitehall, PA
Hi Greg -
The 40-140 has no photofinish. The set you're looking at should refinish real nice though the water stains on top may take some work.
There's a complete list of Philco sets with photofinish here:
https://philcoradio.com/library/index.ph...otofinish/
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 7556 online users. [Complete List]
» 2 Member(s) | 7554 Guest(s)
