Where Is Info On Rebuilding Lamp Socket?
My search for info on rebuilding the Philco lamp sockets that have the hardened rubber has failed.  I tried this link that worked in 2016 but doesn't work now - http://www.philcoradio.com/tech/lamps.htm.
Can someone provide a working link?
Methinks this is what you are seeking: https://philcoradio.com/library/index.ph...lot-lamps/
Yes it is, Terry.  Thanks!
Philco 49-1040
