Philco 41-608 audio output transformer ?
I have found that the input winding of the audio output transformer is open Icon_sad . Does anyone know where I might find a replacement? Thanks much, Gary in Marietta, GA
You need a push-pull audio output transformer to match a 17,000 ohm load (17K ohm) to a 5 ohm speaker. (These are the factory specifications.)
The Hammond HX-125B would be a suitable replacement. It is rated at 5 watts maximum output. Available from Radio Daze and others.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9483 online users. [Complete List]
» 2 Member(s) | 9481 Guest(s)
