Schematic needed DeForest Crosley 245
I have an opportunity to pick up this DeForest Crosley 245 but I’m not able to locate a schematic in all the usual locations. It is missing tubes so I require the schematic to determine the cost of replacing the missing tubes and whether it’s worth buying.
Any assistance would be appreciated.
What style of tubes did it have? Octals or the old style bases with the fat pins for the filaments? Where did you get the model number, and is that the whole number? Did you try Pacific TV's radio schematic pages?
https://radioatticarchives.com/radio.htm?radio=8183
https://antiqueradios.com/forums/viewtop...w=previous
You may have found this as well, but nothing on the Radio Museum
Jim
Spring Lake MI
