Crosley 6H2
Philco was famous for changing chassis, cabinets - everything - in the middle of a production run - several times. The reasons were often clear.
This Crosley is more of a mystery, for me:
https://www.russoldradios.com/blog/favor...-a-mystery
Russ
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8765 online users. [Complete List]
» 3 Member(s) | 8762 Guest(s)
