Volume control for 38-7
We have a Philco 38-7 console we use regularly to play 60's music from a local AM station.
The volume control is scratchy and intermittent and needs to be replaced but has a tapped element not readily available.
The P/N is 33-5216.
I'm looking for suggestions for replacement.
Thank you
Don
Hi and welcome,
Mark can more than likely help you out.  https://www.oldradioparts.net/controls.html  I would call him rather than use the order blank on line.
hello Dan,
Welcome aboard and I second that Mark has saved my bacon more then once .
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
