Signal Tracer 147A
Hello,
I have an EICO 147A. I wanted to check if it works well. I have tried it with a PHILCO 84B. Fully restored Philco. The radio works great. If I play directly with the EICO follower to the 77 grid, nothing is heard through the EICO. But, if I get closer to the grid, without touching it, it can be heard perfectly through the tracer. I would appreciate any clarification on the matter.
