41-226 Restore And The XXD Tube
I am finishing up the electronic restoration of a decent looking 41-226. Lots of tight spaces and rubber wire. The recap went well, except I was plagued with motorboating at the high end of the B/C band.
Looking at the sets construction, I wondered how it ever worked. Open IF transformer under the chassis, and wires running all over the place. I swapped out the tubes one at a time without success. The set came with a 14AF7 in place of the XXD. I tried another 14AF7, with no luck.
Finally I found a real XXD tube, and that resolved the issue. I really don’t know what the difference is between the two tubes, but obviously there’s something. Looking up this tube seems to always list 14AF7. I found a post on ARF with the same issue with a similar radio, and there too, an XXD fixed it.
ARF Post Same Issue
I’m glad this radio is going, and it really pulls in the stations. Nice sounding radio with plenty of volume.
Just thought I’d share this with you in case it comes up with someone else. Beware of substitutes!
Tony
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
Here we are. Boomer Sooner!  :lol: jrblasde — 09:40 PM
