precise 713A power lab
anyone have a decent schematic for a precise 713A power lab? the only one i could find was at
https://antiqueradios.com/forums//viewto...p?t=309831
it is useable, but barely.
Was there any info found for this tester
Some one must have a good copy of this.
Thanks
Moe
looks like radiomuseum has a schematic for download although it may only be the actual schematic not the other pages. It might be more readable. You have to fill in a bit of info to get the download but I've done it before, not hard.
Thanks, I have those already.
Thought there might be something better out there.
A little less fussy
Moe,
I see you discovered the "information" posted at https://antiqueradios.com/forums//viewto...p?t=309831. Non too clear in my estimation.
It has a variac [as you must know]. But with output voltages from 90AC to 140. Any idea why it wasn't designed to start at 0 volts?? Or if it can be modified to start at 0 volts.
Bob
Sorry, Have not spent much time on this unit. Just too limited of info to continue.
Thanks for the interest.
Moe
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6031 online users. [Complete List]
» 1 Member(s) | 6030 Guest(s)
