Philco 89 Questions
It sounds like someone took some liberties with your radio.
Pin 4 of the 77 is the suppressor grid and should connect to ground.
Pin 5 of the 77 is the cathode and should connect to the top of the oscillator tickler coil per the schematic.
If I were you, I would change the wiring to correspond with the schematic.
Yes I will thank you Ron.......................
Jim
Spring Lake MI
Resolved the wiring on the #77 tube and it made a world of difference, can receive station across the dial. Will do an alignment, I am getting a lot of whistling and vibration in the speaker on certain frequency's. Hope the alignment will solve that.
Jim
Spring Lake MI
After an alignment I noticed that from about 1000 kHz and lower freq. the reception will work at times or not. Above 1000 kHz does not fail can always receive.
I had a VOM lead connected to chassis with meter on, with the other probe I would touch the #2 pin (plate) of #77 tube and make it (lower freq's) come and go. Also on the OSC coil I could touch pin #5 (to tuner) and it will cut out, touch pin #4 it will cut in, this is all to do with the lower freq's. If I touch pin #1 or pin#2 has no effect (tickler). Touching pin #3 will also make it cut out.
I don't know if this is a tube (#77) problem or the OSC coil or what.
I have a 6200 ohm resistor to ground instead of an 8000 ohm on the tickler coil.
I have rewound the tickler coil on the OCS coil it was open.
Jim
Spring Lake MI
Finally got this guy up and running. As I said it would work on high freq's and some times on lower freq's. I tried bonding all grounds, replace the OSC cathode resistor back to 8.2K no help. Finally I cleaned the 77 tube socket and replaced the 77 tube after cleaning the pin of the tube. WALA it now works, I am one happy camper.
Thanks for the help.
Jim
Spring Lake MI
Philco circuit master 7004
If anyone is interested in owning this item. Lemeno.  Shoot me an offer or something cool to trade if equal value.  I ...Jdow927 — 01:28 AM
Hello jdow927, Welcome to the Philco Forum and what great gift that meter looks to be in nice shape . Those jacks were...radiorich — 12:50 AM
Brother in law just dropped this off at my house. It is in good shape. Leather strap /handle Is there. No cracks. Case i...Jdow927 — 12:34 AM
Gloritone 27 Radio
Also since motor run caps are non polarized, and typically AC rated, you don't have to worry about ripple, or ESR with t...Arran — 11:32 PM
Gloritone 27 Radio
Motor run caps are also used in portable brush less generators.David — 08:41 PM
Gloritone 27 Radio
Motor caps are yooge. Of course, used with things otehr than motors, they are also almost eternal.morzh — 06:48 PM
Gloritone 27 Radio
I was planning on using motor run caps because the original electrolytic cans, which I believe were in cans, are missing...Arran — 05:40 PM
OK, it worked, but there is that hum issue. I traced it to the balancing resistors from the 47 tube's filament to GND. ...morzh — 02:42 PM
I decided to commit to buying the other 46-480. $75 isn’t terrible, considering that they’ll be traveling through Oklaho...jrblasde — 10:16 AM
Gloritone 27 Radio
I have got petty far along on the radio so far. My chassis is upside down as Richard says. The caps in big clamp are lon...dconant — 09:31 AM
