45F Console - Dial stringing
Hi Folks - I have a 45F Console (released January 1935, same chassis as the butterfly, 45C). Anyhow, I received it with a broken dial string and I cannot find a dial stringing diagram for this one anywhere. Anyone have ideas? -- Andy
Andy Sorrell
Palmyra, Virginia
I do not have a diagram, I have a 45 L would it work for yours?
Hi Paul! Thanks for the reply. I would expect the 45L should look the same - chassis should be the same at the 45F, just in a different cabinet. Any photos would be super helpful! -- Andy
Andy Sorrell
Palmyra, Virginia
Thank you very much. I'll let you know how it goes.R3Sons — 11:00 PM
Hello mike, Nice job hopefully it works and I am sure it will. Sincerely Richardradiorich — 09:15 PM
Hello Peter, I am glad you got the radios and I too have that same zenith in my collection ! I am also waiting for the...radiorich — 08:52 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
