Labels for 630B
I'm making my own sticker lables for the rear chassis but a couple were missing and couldn't find any good images on the net. The blue Model # label is not the correct one for the 630B. Anyone know the chassis no. and exact wording for the right label? Also i believe there was a 3rd label of patent#s I also need. thanks
https://philcoradio.com/library/index.ph...sis-label/
Oh! lol i missed that bigtime. thats much better than mine... Thanks Bud!
