Philco 46-1226 Code 125
A customer brought me a model 46-1226 and I discovered it was a Code 125. The schematic was never drawn and the closest you can get is a Code 122. There are also several factory revision sheets which address factory changes to the 122. Hoping that someone on the forum can help. The owner pulled all of the tubes and put them in a bag. I cannot even start. The power supply is different since it uses a PM speaker. Please contact me if you can help.
Thank you,
The documentation in our library includes the code 125 power supply info you mentioned along with the changes that go with it. Does this help?
https://philcoradio.com/library/download...6-1947.pdf
Yes, this helps.
Thank you
Icon_thumbup
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 2369 online users. [Complete List]
» 2 Member(s) | 2367 Guest(s)
