CoRadio Help
#31
Hi Mr. Big,
Remember when I said I never saw a 6 Tube with an untuned grid circuit on the converter, then found your CoRadio, then I found the FADA1000. Now, I found a Belmont 6D111, the link below. This one has a tube chart with pin voltages.
http://www.nostalgiaair.org/PagesByModel...002220.pdf
Good luck with the Philco 90 and this one when U get around to it.
Thanks!! I have found another schematic that is pretty close to the one I have. However, the "Tradio" schematic has more capacitors than what is listed on the one I have been trying to use.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 4654 online users. [Complete List]
» 1 Member(s) | 4653 Guest(s)
