Atwater Kent Kiel Radio Table
I just picked up a Kiel Radio Table with a model 55C chassis in it.  Does anyone know who to tell if it's a late model or an early model?  I have found drawing on but some of the voltage test points are different, so I think I need to figure it out, so I know which drawing to use.   Although there are not too many differences between the two it appears.  Can it be broken down based on the serial number?
Philco's
86 Low Boy     71B      42-321T
90 High Boy    52B      46-1203
95 High Boy    118B     48-214
112X Console     60B       48-206
118X Console     84B       49-506
41-608P Console   610B   76 High Boy
41-265 Console   37-89B   370LZ
52GC                38-35B
20 Baby Grand   38-10T
70 Baby Grand   41-221CI
If you are a FB member there's a group for that.
I see from the replies you've gotten on FB there's no definitive answer to your question. A lot of changes though a production run for any number of reasons go undocumented. In the early '30s cost could be a good motivation or better performance.
GL w/your AK and may your transformer failures be few.
Here is a discussion of the changes:
https://antiqueradios.com/forums/viewtop...=6&t=70452
All links are now dead. Try web archive for a copy of the entire atwater-kent web site.
etorre, an ARF member is currently restoring an A-K 55.
Chas
Pliny the younger
Thanks to all.
Philco's
52GC                38-35B
Here's the thread for the table and radio restoration I did a few years back in case its helpful for you...
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 7644 online users. [Complete List]
» 1 Member(s) | 7643 Guest(s)
