Philco 41-95 Dial Cord Diagram
Good morning all!  Thanks for accepting me into the PHILCO Phorum.
I'm working on a Philco 41-95 farm radio.  I've rewired the entire chassis and replaced all components.
I'm looking for the dial cord diagram for this radio.  I've located numerous pictures on line and I think I've solved the problem, but if anyone happens to have a diagram of this, it would be greatly appreciated!!
Thanks in advance!!
Ken Ballard
Welcome to the Phorum! I moved your request to Philco Home Radios. Post a photo when you can. Take care and BE HEALTHY! Gary
