Resistor Advice Needed For A 1936 Philco 650
Hello Everyone,
 I need advice regarding resistor replacement in a 1936 Philco 650 chassis that I am restoring. Most of the resistors in this radio are out of tolerance and check much lower than specifications. The Rider's schematic does not list any wattage ratings. Are 1/2 watt carbon composition resistors adequate to use throughout? Several of the resistors are dimensionally very large. Any advice or recommendations would be appreciated. Below is a link to the schematic. Thank you.
Tony
http://www.nostalgiaair.org/PagesByModel...013824.pdf
https://philcoradio.com/library/index.ph...resistors/
Tony,
Looks like Terry has you covered.
If you email me at the address I PM'd you with, I'll email you the parts price list with values.
Carl
Northern Panhandle, WV
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9585 online users. [Complete List]
» 2 Member(s) | 9583 Guest(s)
