Model 84 speaker recone service orkiy
Hello fellow phourm members.
Im looking for a recone service for a 1934 model 84.
Thanks
Bruce
Finally after 50 plus years I'm back into the hobby again. It's like trying to relearn a second language some of it makes sense and some of it doesn't! Could be fun now considering my son is now into old radios and tube technology!
Sound Remedy in NJ (Rich Stamer) is my go-to place.
I second that recommendation.
