37-60 revision 6
I am restoring a Philco 37-60 and it shows run 6 they removed the ground from G3 of the 6K7G and put the G3 to -2.5v for negative bias my radio does not have this run 6. by doing this will the make the shortwave reception any stronger.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 3937 online users. [Complete List]
» 1 Member(s) | 3936 Guest(s)
