Push Button light location on a 41-300
Well... I have a working 41-300 chassis, finally Icon_biggrin . This model has 5 lights including one that lights when the band selector is in the lowest position indicating the push buttons are active. The lamp holder was loose when I took the chassis out and don't know where it should be. Does anyone have a picture or can tell me where it is to be located.
Glenn
Happily back in Illinois..not.
That lamp socket is on a strip of metal, mounted to the front of the chassis and sticking up so it is sort of near the pushbuttons.
Thanks Ron. I thought so but it just didn't look right.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
