Re-Flocking Tuning Dial Plate
Anyone have any suggestions on where to find a suitable brown flocking for 41-295/300 tuning dial plates? Failing that, how is the best way to clean that flocked surface?
Hobby shops sell flocking. The people at West_Tech have flocking in many colors and do a nice job re-flocking turntables.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6246 online users. [Complete List]
» 1 Member(s) | 6245 Guest(s)
