Philco Model 48-460 Code 122
I have a acquired a beautiful 48-460 which I am about to restore. I have pulled a copy of the data off of Riders but it is a 48-460 Code 121 and my radio is a Code 122. I have heard they are similar but this is not. For instance there is no antenna coil on this Code 122, which a 121 has, and there were 4 leads from the internal antenna being used on this model. Also the electrolytic values were not exactly the same. Does someone have a schematic of the Code 122 model that I could have.
Please reply to the identical topic here:
http://www.philcoradio.com/phorum/showth...p?tid=2775
This one is locked as duplicate threads on the same topic are not allowed.
Philco 89 indicator light.
There are currently 8251 online users. [Complete List]
» 1 Member(s) | 8250 Guest(s)
