1948 Victrola 77U (with Phonograph)
I just aquired the above unit, Recapped it and got her all cleaned up. Radio working great, turn table works and all mechanics are doing what they should. My problem is I am not getting any sound from the needle, and all wires are intact. Has anyone here had any experience with these units?
Jerry Gatewood
Philco 41-280 (121)
As with any player with a crystal pickup, the cartridge will be dead. You'll need to find someone who can open the pickup case, and put a crystal element in place of the dead one. These elements are gotten from newer "donor" pickup cartridges.
I understand that it isn't vary hard; just tricky, but by doing that, you can have the set back in operation once again.
Thanks Doug, I was afraid of that. I will just restore everything and leave that until I can find one. There are absolutely NO resources on the internet for this particular radio at all.
Jerry Gatewood
Philco 41-280 (121)
There is a thread here on the Phorum which shows you how to rebuild your own crystal cartridge.
http://www.philcoradio.com/phorum/showth...p?tid=1019
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 6476 online users. [Complete List]
» 2 Member(s) | 6474 Guest(s)
