37-61 Open SW Oscillator Coil - Proposed Fix
I'm working on a 37-61. The primary (feedback winding) of the Short Wave oscillator coil, part 10, (lugs 3 and 4) is open. The schematic is here:
http://www.nostalgiaair.org/PagesByModel...013208.pdf
The feedback winding appears to be inside the form or otherwise not accessable. As a fix, I am thinking about trying to wind a feedback winding on the outside of the form, near the cold end. The tuned winding is about 18 turns of fairly heavy wire. I am thinking that 3-4 turns for a feedback winding, of fine wire, should work OK (although I only have a 50% chance of getting the winding direction correct!) But the coil is fairly accessable.
Any suggestions? Alternatives?
Thanks
I would try it! Youve nothing to loose. Experimenting with different amt of "turns" both clockwise & (vs) counterclockwise 50/50 chance,may yield best results, to get your set working. I remember yrs ago I had similar success with just a few-turns of small 18 ga solid insulated wire on a very old 28 model Gloritone Cathedral AM set with similar probs. I used a small pc of cardboard ( center of paper towel roll type),..to wrap around the orig coil 1st, then experimented with the new windings in both directions before I acheived success.Go for it!! Icon_biggrin
I decided I could not live with my originally proposed fix, so I decided to try and repair the coil. In the photo below, the Short Wave oscillator coil is the one to the top left. You will notice it is the only one with a DOUBLE form.
[Image: http://mcclellans.com/3761.jpg]
I first removed the coil from the RF Subchassis assembly - not an easy task! I noticed that the top lead of the OUTER coil, which is about #20 wire, passed all the way through the coil (both the inside and outside forms). So I pulled it back through the coil and then secured it with tape to prevent the outer winding from unwinding (held only by wax at this point). It was obvious by looking from the bottom that the inner coil form did not extend the whole length. Next I inserted a 25 watt pencil soldering iron tip into the top of the coil and moved it around to free the inner coil form. I correctly guessed that it was only held by wax. Once the wax on the OUTSIDE of the coil form started to melt, I was able to push out the INNER form using a screwdriver.
After the wax was melted off the inner coil form, the Philco green disease was obvious! I started unwinding the coil, but it was broken at about the same place on each turn. I removed the entire coil. The impressions left made it obvious how many turns were needed, as well as the winding direction. IIRC, I think it was about 16 turns. I rewound the coil using #38 cotton covered enamel wire. Once continuity was determined, the inner coil was re-inserted into the outer coil form (the trick is to align it so that the top of the outer coil can be reinserted through both forms).
The coil was then reinstalled and tested. We'll see how it works once I complete the restoration.
The RF subchassis restoration is complete - with all caps restuffed and one resistor replaced.
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
