grill cloth 37-630
I have to replace the grill cloth on my 37-630. I think the correct match would be pattern #3 at http://www.grillecloth.com . Is this pattern a match to the original? Does anybody know of a source of original material?
Thanks
Doug
If your 37-630 is the console (37-630X), then yes, you will want to use pattern #3.
If it is the table model (37-630T), you need pattern #11.
Hi Ron,
I should have stated that it was the console model. Thanks for the information.
Take care,
Doug
There are currently 9775 online users. [Complete List]
» 1 Member(s) | 9774 Guest(s)
