Model 70 1st det. coil
Hi All,
I'm working on a model 70 and I have an open primary winding on the 1st detector transformer- Philco part no. 03083 item number 6 on the schematic. Does anyone have the info on how many turns, which direction and gauge of wire? Any info would greatly appreciated! Thanks!
Took a quick look at the diagram and the winding you are looking to rewind is a non frequency determining (untuned) The number of turns is not real critical. What I would do is use some #36-38G wire. Rewind to fill the same space of the original. I would suspect it's about 55 turns. You can determine the direction when you remove the old one.
Thanks for the info Terry! I pulled the coil out and found out the direction (should have thought of that earlier!). I've measured the width of the winding and will try to count the turns.
Kevin
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8239 online users. [Complete List]
» 1 Member(s) | 8238 Guest(s)
