Antenna for a 48-200
I've got a little 48-200, missing the antenna , all it was is coil of wire glued to the case, plastic. I have not had much luck in finding one ,so I'll try to make on, need to know guage and how many turns ,can any one help?
What you may want to try is replacing it with a back cover from another set any brand with a loop antenna wound on it. Or a ferrite loop stick. Isn't very critical I would think that 40 turns or so of 28 to 35Ga wire. A secondary could be wound to be used to connect an outside aerial. About 10-15 percent of the primary, 4-6 turns. This will make it possible to connect the antenna with out being concerned about grounding and shock hazard if this set is a transformerless job.
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5051 online users. [Complete List]
» 4 Member(s) | 5047 Guest(s)
AvatarAvatarAvatarAvatar
