replace bakelite condensers on 84b ?
hi..im a newbee!
can i replace & bypass the 4 bakelite condenser blocks in my 84b with the correct value orange drop capacitors? the blocks are stamped 3793-ad .... 7762-b ..... 4989-ak ... 7625-h . if i can bypass them,should i remove them? how do i know what value caps to use for each block replacement? thanks all! this site is so great!!!
STEVE ADORNO
nylatinrock@yahoo.com
Onroda MusicWorks - http://www.amazon.com/Seguida/e/B001LHDMN8
Welcome Seguida...Yes,you can rebuild them...read up on them here on.Take your time,and you can use the orange dips.
http://www.philcorepairbench.com/bblokcap.htm
http://www.philcorepairbench.com/capbuild.htm
THANKS CHICAGO!! GREAT INFO!!!
STEVE ADORNO
I used safety capacitors (Y2-type for line-to-ground) in mine, justradios.com recommends them for this application. Easy process, except somebody at some point put so much solder on that it took quite a while to desolder the terminals. When I finally got the thing out of the chassis, the solder pen had gotten the whole condenser warm enough that I didn't even need to use a heat gun to get the tar plug out...just stuck a straightened paperclip inside and the whole thing came right out. Icon_thumbup
http://www.justradios.com/Y2capacitors.html
Dave
thanks dave! great tip!! would you happen to have a jpg photo of your completed recapped 84b chassis ? it would be most helpful....
thanks again!
STEVE ADORNO
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7360 online users. [Complete List]
» 4 Member(s) | 7356 Guest(s)
AvatarAvatarAvatarAvatar
