Philco 16B code 125 cabinet color
I am restoring a Philco 16B code 125. The photos that I find on the internet all seem to show the body of the radio cabinet being black. My radio definitely did not apppear black. Very dark but not black. I did not strip it but feathered the damaged areas and blended the new finish over the old. I used a dark mahogany toner on the body and clear lacquer on the front accents. The dark mahogany is a tiny bit lighter than the original finish but I thought it might have darkened over the years. Was I wrong and the original finish was black?
Also anyone have any suggestions as to putting the gold accent stripes back in the grooves on the front? I tried using gold paint and a artist brush and had poor results. Too shakey....
Also was there ever any decals on the controls? The only decal on mine was the Philco logo above the dial.
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Terry I have the 16B and when I asked Ron and he suggested dark walnut or Van Dyke brown. He added that in some lighting conditions the Van Dyke brown had a green cast to it. On the gold accents, can you get automotive masking tape and a small razor knife and then cover the the insets with tape (maybe one layer) and then use the razor knife to cut out the inset area and use gold spray lacquer. I would think as long as you mask the front off after you have the insets cut that would prevent any overspray issues. He definitely stated "don't use black".
Thanks stud.
Here is the finished radio. Dark walnut might have been better but it looks OK to me...
[Image: http://home.comcast.net/~suptjud/Philco165.jpg]
Kind regards,
Terry,
VERY NICE! With the lighter color, it brings out the grain and yields a terrific look. I'd go with it just like this! Two thumbs up! 8)
Bill
Sent from my Pentium II on the AT&T Dial Network
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 2187 online users. [Complete List]
» 2 Member(s) | 2185 Guest(s)
