Dick Oliver Reproduction cabinet parts
Just wanted to give any of you guys who have an early Philco cathedral that has a busted out grill or missing arch a heads up. Just got in the parts for my Philco model 21. Base board, molding, front panel, and arch. All parts are excellence!! All details good no rough edges just ready to be installed. Can't wait to get it all together!
Unfortunately, due to ill health, Dick Oliver is no longer in the business of reproducing Philco cabinets or cabinet parts.
There are currently 9967 online users. [Complete List]
» 2 Member(s) | 9965 Guest(s)
