Square or round cans on model 80
Seems like I've seen both square or round cans over coils on the model 80. Any significants? Didn't know if can help determine age or whether it's an early or later run.
For what it's worth, the only Model 80 I have ever seen that had round coil shields was a Canadian version - and it used two 77 tubes instead of two 36 tubes.
There are currently 8878 online users. [Complete List]
» 3 Member(s) | 8875 Guest(s)
