42-340 Tone control/power switch replacement
This is probably an easy one for you Philco Gurus. 42-340 receiver, Someone has replaced original tone control/power switch with a toggle that operates only the power. Appears to be a 3 pole 3 position switch on the schematic. Where could I find a suitable replacement, to keep original functionality? Thanks in advance.
Hi
Actually, it's a two pole, three position switch.
This switch on eBay will work well for you:
http://cgi.ebay.com/160365456281
Alternatively, a Lorlin rotary switch from Mouser will also work.
Thank you so much Ron.
The speaker table error?
Philco 70 antenna lead
