Model 20 Consolette Resto
#46
The Admiral sounds good. It just has two wires they would take the place of the field coil.
If it is too small inductance wise you well still have some 60cy hum. Any inductor is going to be better than a resistor. If it is too small current wise it will run hot.
Ok. I will let you know how it turns out. Thanks for the advice. Icon_biggrin
There are currently 9641 online users. [Complete List]
» 1 Member(s) | 9640 Guest(s)
