replacing rubber insulators,Philco 16x
Threads: 145
City: Elko,MN.
Hi guy's,
I am working on a 16x console and need to replace the rubber insulators on the tuning condenser.
Any secrets to removing and re-soldering the ground straps on the 3 mounting screws?
My 45 watt weller soldering iron doesn't seem to do the trick.
I also want to replace the electrolitic caps.
Anything special I should know about changing these?
Thanks in advance for any suggestions.
murf
Threads: 112
City: Medford OR (OR what?)
A 100W or larger "gun". Sometime I have to use and my iron, both, to get nice flow.
Threads: 145
City: Elko,MN.
Phlogiston Wrote:A 100W or larger "gun". Sometime I have to use and my iron, both, to get nice flow.
Thanks for the info.
Don't know where I can get one of those?
murf
Threads: 8
City: Lexington, SC
Prefer a plumber's propane torch turned down low. Use aluminum foil around any wires, etc to avoid burning any other items. Prefer to take the chassis outside.
Richard
Threads: 145
City: Elko,MN.
rghines1 Wrote:Prefer a plumber's propane torch turned down low. Use aluminum foil around any wires, etc to avoid burning any other items. Prefer to take the chassis outside.
Richard Wow,that sounds dangerous.
How do keep from burning everything else up.
This chassis has a lot going on.I would spend days wrapping everything in tinfoil.
Think I will stay away from this.
Thanks anyway.
murf
Threads: 117
Hi Murf, You can find the larger wattage soldering irons used on ebay. Search for "large soldering iron", there are several on there now. The old style irons with the wood handles and cloth a.c. cords last forever and are usually in the 150 watt range. The tips last forever, about 1/4" in diameter, you will never need to change them. After those type irons heat up for about 10 minutes, you can unsolder the big braided ground wires on radio chassis easily after applying the heat for a few minutes. They also work great for direct to chassis connections. I have 2 of those type irons here at my shop, don't use them often, but when needed for what your doing, they work great!
Threads: 145
City: Elko,MN.
Texasrocker Wrote:Hi Murf, You can find the larger wattage soldering irons used on ebay. Search for "large soldering iron", there are several on there now. The old style irons with the wood handles and cloth a.c. cords last forever and are usually in the 150 watt range. The tips last forever, about 1/4" in diameter, you will never need to change them. After those type irons heat up for about 10 minutes, you can unsolder the big braided ground wires on radio chassis easily after applying the heat for a few minutes. They also work great for direct to chassis connections. I have 2 of those type irons here at my shop, don't use them often, but when needed for what your doing, they work great!  Found one on Amazon for $18.00.
Will give that a try.
Thanks
murf
Threads: 117
Hi Murf, what kind of heavy duty soldering irons are avail on Amazon? Pls post link here if possible. Are they the 150 watter big irons?
Thats great you found em online!! Thanks, ol Tex.
Threads: 54
I have a 100 Watt iron and a 200 Watt iron, one came from a garage sale the other from a car swap meet, one is an ESICO and the other is a Solder Master but a Canadian or American Beauty will work as well if it's the right wattage. I use the 100 Watt one all the time for soldering or unsoldering things from a chassis and for soldering connections in house wire. It's almost always cheaper getting an old second hand iron and they are usually American or Canadian made, not Chinese, so they last.
Threads: 145
City: Elko,MN.
Texasrocker Wrote:Hi Murf, what kind of heavy duty soldering irons are avail on Amazon? Pls post link here if possible. Are they the 150 watter big irons?
Thats great you found em online!! Thanks, ol Tex. The one I bought is just a cheap one.
Did not look for anything bigger than a 100 watt.
Just bought it for very limited use.
murf
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
