Need turntable for 48-1270 phonograph
I just gutted my Philco 48-1270 and sent the radio chassis out for a rebuild. Now that it's under way, I need one missing part; the turntable "platter" for the phonograph. Grandfather loved trains and used the original one to build a roundhouse for his layout decades ago, so it's gone forever.
Anyone have a platter they can sell?
This is a "Wanted Ad" and belongs in the "Wanted Ads" section.
However, you have already posted an ad there, so I am locking this thread.
Multiple postings on the same subject are not allowed under Phorum rules.
Quote:II. Multiple threads on the same subject not allowed.
When you start a thread, please keep the discussion within the same thread.
http://philcoradio.com/phorum/showthread.php?tid=4586
The speaker table error?
Philco 70 antenna lead
