Philco Radiobar 528
I am a new member here, and have a question about a radiobar.When looking at the reference in Ron's radiobar research he has it listed as a model 528 37-620 which is confusing.The chassis in the radio has the tube line-up 80/6A7/78/75/78/42/42/42. It also has an oval dial with 4 band 8" speaker and shadowmeter. The radio has doors over the radio with what appears to be 4 chrome? strips on each side. What do I have? and what chassis is this? Thanks....Don
What's confusing about it? It is how it is listed in the 1937 Radiobar brochure.
But I do know that Radiobar used some of the same cabinets for more than one selling season. As an example, the set Radiobar sold in the 1937 season as model 507-37-610 came with a model 60 chassis in 1936, possibly 1935 as well.
The oval dial was only used during the 1936 season.
Four bands, and the tube lineup you listed, indicates a 1936 model 650 chassis. But as far as exactly which Radiobar model you have, I can't say as I do not have any paperwork for older Radiobar models.
1. Have you tested out of circuit? 2. If yes, any transistor not showing E-C as OL is bad. From your measurements, all...morzh — 08:27 PM
42-345 Resistors
In short (I a sure you've seen the video Rich provided), safety caps are X and Y. X caps are placed across the Line/Neu...morzh — 08:21 PM
Restoring Philco 96
Today I decided to take on gutting the big bad cap block. I gave up on the same one from the 86 before, so I was not sur...morzh — 08:13 PM
42-345 Resistors
To not replace is to put it on the list to do later when they cook up! As a radio guy would say back in the day, lets sp...Paul Philco322 — 07:19 PM
Here's the readings from the AR14 (No markings on the one from the 5TPO) on the 6TPZ: B-E OL E-B .14 B-C 2.9 C-B .13...R3Sons — 04:17 PM
Thank you all so much. First the power supply: "KORAD KA3005P - Programmable Precision Variable Adjustable 30V, 5A...R3Sons — 03:48 PM
Perhaps I am missing something - which volume (AR-28 or AR-33) has the 6TPZ?DaleHCook — 12:16 PM
1950 Emerson TV resurrection attempt
:lol: Ya got that right Mike! I watched it some last night for a couple hours and it seemed pretty stable. Not bad for a...TV MAN — 11:05 AM
Is your power supply adequate? Perhaps it cannot source the current required. Or...bad transistors.morzh — 09:32 AM
Hi R3, just glancing over the schematic,if C1 and C2 are good and they appear to be by the voltage you are getting on TP...462ron — 08:28 AM
There are currently 2950 online users. [Complete List]
» 2 Member(s) | 2948 Guest(s)
