transporting my philco 37-630X
Phil,
Thanks, All knobs are a very dark brown... If you are referring to the on/off knob it is the same as the tuning knob, you just can't see the pointer in the photo.
Kurt
Wow, if both bottom knobs are the same that is quite the optical illusion. But shadows and angles can do strange things.
Phil,
I just realized the problem... Look at the fine tuning knob... I must have moved it to it's correct location after I took the photo....When received your first message I went and looked and the knobs were in the correct position.. lets just chalk it up to a senior moment .. ha.. ha...
Looked at other online pictures and the fine tuning knob does not appear to have a pointer.
Good Catch !!
Kurt
Ah yes, I see what you mean. Just the two were switched. Mystery no more.
Philco 91 Tuning Condenser
There are currently 4809 online users. [Complete List]
» 1 Member(s) | 4808 Guest(s)
