Need Philco 345 readable schematic
I would like to know a source for downloading a readable schematic for a Canadian Philco model 345 code 122 radio.
I have schematics for models 45 but not for 345. Someone has been in the radio and put a 47mf cap in somewhere,and I need to see if I can find out what the right ones are.
Thanks Dan
   Living in Calgary Alberta
Dan
I have the Radio College of Canada schematics on a DVD, which is sold by a collector in Canada.
I looked at the 345 schematic...hard to read, and you can't make out most of the part values, but I compared it against the USA 45 schematic and they are the same.
I'll send you a copy of this schematic if you want it, but like I said, the scan is not very clear.
Thank you Ron.. I do have the same RCC disk and it is not very readable,that is why I put the request on the forum.
I will see if I can decipher the schematic.
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6852 online users. [Complete List]
» 1 Member(s) | 6851 Guest(s)
