Philco 60 Alive Again!
#31
Was thinking that you may have shorted plates on your tuning condenser. To do this you will need to measure the resistance from the stator plates ( the plates that don't move) to the frame of the condenser with the plates closed (max capacity) Should measure open.
Hi Terry,
OK. Measuring from the non-moveable plates on the tuning condenser, on the front set, toward the dial, read open, (30-40 Meg Ohms). The rear non-moving set measure 45K Ohms across the entire span open or closed.
Maybe a clue?
-Brett
#33
As an update, I've removed the tuning condenser from the set. Now all of the non-moving stator plates are isolated from the frame. The wire that goes from the rear most connection of the condenser, to pin 5 of the 6A7 reads 45K Ohms.
-Brett
#34
Seems like that wire should be a dead short as per the diagram. Go ahead and replace it and if that gets you working again.
The speaker table error?
Philco 70 antenna lead
There are currently 6948 online users. [Complete List]
» 1 Member(s) | 6947 Guest(s)
