Question about Philco M-1430
I recently came across a Philco M-1430 portable record player/phonograph. I've tried to do some research on this particular model but have been unsuccessful. I was wondering if anyone knew if this is rare or potentially valuable? It's in pretty good condition and still plays with no problems. It has all the original paperwork. Any help would be appreciated!
Thanks in advance!
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Philco 91 Tuning Condenser
There are currently 4083 online users. [Complete List]
» 1 Member(s) | 4082 Guest(s)
