what # pilot lamp for philco 84b?
anyone know what pilot lamp number is use for a philco 84b?
steve!
STEVE ADORNO
nylatinrock@yahoo.com
Onroda MusicWorks - http://www.amazon.com/Seguida/e/B001LHDMN8
Steve,
Philco p/n 6608, #46.
Carl
Northern Panhandle, WV
THANKS CARL!!
STEVE ADORNO
hi radio people!
does anyone out there have a replacement "dial pointer" for a philco 84b? or... possibly a template to cut a new one??? its just a tiny cardboard thing.... steve
STEVE ADORNO
The speaker table error?
Philco 70 antenna lead
