Speaker Philco 37-84B
New to antique radio repair and I just received this Philco radio. The cone is badly damage but I think I could repair it. Before spending a lot of time on this, is there a way to test the speaker. It is disconnected from the radio and there are three wires. With a 9 volt battery I do get a very soft static when touching the voice coil wires and a resistance of .4 ohm. Also the three field coil wires measure 1.166 K ohms between one pair and 1.5 K ohms the second pair...and I am sure it is used as a field coil. Your comments greatly appreciated.
Sounds good!
Thanks, Terry!
The speaker table error?
Philco 70 antenna lead
There are currently 7677 online users. [Complete List]
» 3 Member(s) | 7674 Guest(s)
