Correct power/volume knobs for a 116X?
Anybody have a closeup pic of the pwr/vol control or tone control knob for a 1936 116X?
Larry
Hello, Larry: they are the same black knobs found on nearly all of the 1936 models. Pretty common.
There are currently 10602 online users. [Complete List]
» 2 Member(s) | 10600 Guest(s)
