Never say never
Been looking for a PP 45 Philco 90 chassis for awhile now. Couple of weeks ago saw an ad in Craigslist for two very rough consoles, 20.00 each. One looked like it might be a 90, so what the heck, I went to check it out.
Yep.... a model 90 with the PP 45s and a speaker to boot. Has all of it's tubes, including one blue arcturus globe 27. Also has both copper mershons. Twenty dollars well spent.
CONGRATS!!!!!
Seek and yea shall find!
Nice find! Deals like that don't come up to often!
-Keith
Thanks, guys. Also found a Philco 111 in SC on the same trip, but bad news is that it was the week after I was released from hospital for Pneumonia, and my rash of activity caused a (unprintable) relapse!
Photos will follow soon, right now am trying to anticipate my visiting nurse' routine so that she doesn't suprise me doing somthing I'm not supposed to be doing. Icon_wink
Philco 91 Tuning Condenser
