replacement or template for "dial pointer" philco 84b
HI RADIO PEOPLE!
does anyone out there have a replacement "DIAL POINTER" for a philco 84b? or....possibly a " template" to cut a new one??? its a tiny cardboard thing......or.... can some kind collector please just photo one and post it here?? maybe i can cut one from that.. steve
STEVE ADORNO
nylatinrock@yahoo.com
Onroda MusicWorks - http://www.amazon.com/Seguida/e/B001LHDMN8
(03-21-2012, 05:51 PM)seguida Wrote:  HI RADIO PEOPLE!
A lot or sets used them but most are missing. Some of the later sets have metal ones but they get lost too. I could use a few myself.
I found an old thread on the Phorum with photos of one. I also found an thread on ARF where Mark Oppat says he has replacements although I don't see them listed on his site.
Phorum thread:
http://philcoradio.com/phorum/showthread...0&pid=3096
Mark Oppat's site:
http://www.oldradioparts.net/
Sean
WØKPX
I've just gone through the old Phorum page linked above and corrected links, added photos where photos were missing, etc.
thanks ron for this info on dial pointer...i hope i can make one....
STEVE ADORNO
The speaker table error?
Philco 70 antenna lead
