Model 91 alignment
I don't know if I'm too tired to see the obvious, but I'm having trouble finding an alignment procedure for the model 91 cathedral. It's the standard model, 110 volt, single speaker, code 123. Can anyone help??
Thanks in advance
I found it the next day in the specific Rider book.
