48-200 wiring diagram
I'm starting to do my first complete recap. Since I haven't worked on a radio since I was a kid I'm a little rusty. I have a schematic and I thought I was being very careful but I'm knd of lost. I remember that there used to be circuit drawings as well as schematics. Does anyone know where I can get the circuit drawing.
Eric
Eric
The Villages, FL
The component layout is in the Philco Service notes. Check with Chuck Schwark.
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 3767 online users. [Complete List]
» 2 Member(s) | 3765 Guest(s)
