Philco Logo
I was working with a mail order screen shop to apply the Philco Logo on a small towel to place on my Radio Top. They declined to reproduce because of potential Patent Infringement concerns. Anyone have similar experience? I sent them the JPG found on the internet?
Radioguy, if there is a problem concerning legal action for copying this stuff for personal use, I'm in trouble. Cruise down through the attached thread and look at my wife does for the tops of our consoles.
Jerry
http://philcoradio.com/phorum/showthread.php?tid=5046
Jerry. Yes that is a great idea. She does good work. My goal was to translate the jpg file to either screen image for printing on a cover cloth or to an embroidery shop. It cost aprox 40 bucks to get the file into ia DST format. Than another 20 to have it sewn..but they refused to do it due to copyrigt concerns... I stiil will keep looking for an easier vendor.
Philco 91 Tuning Condenser
