Signal Generator and Frequency Counter
I am in the process of purchasing a used restored (recapped, tubes checked out, aligned, tested) signal generator for alignment of AM tube radios.
I settled on a Eico 324 Signal Generator after looking at several threads on the Phorum.
Do I also need a frequency counter as well and what (beside checking the signal generator) would the frequency counter be used for.
If it is something that is needed can I get some suggestions regarding either a cheap new or reliable used frequency counter. I might want to add this as a late entry on my Christmas list.
Thanks.
I use it every time I use the signal generator. This ensures you are right on the IF. I aligned a 42-340 without one and it came out ok, but then I purchased a frequency counter and found the generator was off by 10. So I did it again, and what a difference it made. So I say go for it, they are fairly inexpensive.
Glenn
Happily back in Illinois..not.
+1 what Glenn advised. The frequency cunte ensures that you are right on the frequency you need to have.
There are several inexpensive models that are good instruments, start with eBay.
The part, tool you get from HD is inside the plastic, like in a bubble.RodB — 07:17 PM
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 10894 online users. [Complete List]
» 2 Member(s) | 10892 Guest(s)
